96 blazer not getting gas?
I have a 96 blazer with the 4.3 litre. cannot get it to start now. i disconnected the fuel line at the filter and when i turned it over, it spit gas from the filter. used starting fluid, ran until fluid ran through. no clue what it could be... any ideas?
Run a fuel pressure test as described in the Tech Article on the subject and report back with the results (psi reading with key-on engine off as well as the psi reading 10 minutes after the pump shuts off).
bagged02
May 23, 2012 09:01 PM
JerryB52
Jul 13, 2011 06:35 AM
