96 Blazer Trasmission/Brake Issues?
Old Jan 18, 2013 | 04:54 PM
Jowatana's Avatar
Jowatana is on a distinguished road
Default 96 Blazer Trasmission/Brake Issues?
I have a 96 Blazer with 130K miles. Recently I have had issues when shifting out of Park or Drive and into Reverse. Upon moving the shifter and placing into into R the engine will die, not always and not predictably - hot, cold etc. It also die recently while rolling up to an intersection, the engine cut out as soon as I hit the brake. Always starts up immediately afterward, battery, alternator all checkout OK. It doesn't have a problem as long as I move passed R as well e.g. P to D. Is there some electrical issue from the steering column or something larger in the transmission? Any ideas? Doesn't seem to present any other transmission issues.
Old Jan 20, 2013 | 08:43 PM
medivh25's Avatar
medivh25 is on a distinguished road
just for giggles check the connection to your ICM, With the truck running wiggle it around a bit and c what happens.. I chased a problem like yours on my trans am for along time turned out to be a almost broke wire in the icm plug.
top jimmy
Jan 18, 2012 12:28 PM
LowFlow
Mar 28, 2011 02:15 PM
Manag
Jan 31, 2011 02:44 PM
tigerhwk
Jun 28, 2008 03:55 PM
rob1621
Apr 10, 2008 07:39 PM
