Brake issues on Blazer -74
Old Mar 27, 2011 | 03:22 PM
LowFlow's Avatar
LowFlow is on a distinguished road
Default Brake issues on Blazer -74
Hey!
I just replaced both calipers in front. Right side went fine, got the air out by pumping/holding method. Fine..
Left side.. *sigh* I cant get a single drip from the hose.. The brakeline from that thing thats under the radiator looks fine to me. The hose doesnt look damaged either.
What can the problem be? Any ideas? Can this thing under the radiator block the left line?
Old Mar 27, 2011 | 05:37 PM
The rubber flex lines can swell internally and look almost new on the outside. Try cracking the line loose at the other end of the rubber flex line and see if you get fluid out of it? If you do, replace the flex line.
Old Mar 27, 2011 | 07:09 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
this would be what i would suspect if you crack the line before the rubber and get fluid the rubber line is most likely collapsed internally.
Old Mar 28, 2011 | 11:58 AM
LowFlow's Avatar
Okey thanks guys. I decided to remove the rubber line, and yay! I got fluid! Ordered a new rubber line today, hopefully got it before weekend.
Thanks for all the help.
Old Mar 28, 2011 | 12:04 PM
If you can swing it, financially, I would go through and replace every rubber line on the truck (should be three total). They may all be the same age and why have the potential of another line swelling up inside, cutting out or locking up your brakes on you.
Old Mar 28, 2011 | 02:15 PM
LowFlow's Avatar
Probably. But my goal atm is to finally try the fkin truck :P
Will probably be a total do-over later.
blackbear
Oct 7, 2014 06:49 AM
Jowatana
Jan 20, 2013 08:43 PM
Blazer1189
Sep 4, 2012 10:18 PM
Manag
Jan 31, 2011 02:44 PM
tigerhwk
Jun 28, 2008 03:55 PM
