96 chevy blazer automatic 4l80e swap fitment
Old May 18, 2016 | 09:52 PM
albertochvr's Avatar
albertochvr is on a distinguished road
If I do rebuild what brand is good my neighbor says alto clutches,I would add some sonnax parts to the valve body.Any recommendations are welcomed that's why Iam here.I bought my truck for 300 bucks and just did the intake gasket of course I used fel-pro perma dry.
Old May 18, 2016 | 09:54 PM
rexmburns's Avatar
Super Moderator
Originally Posted by albertochvr
Pcm reprogramming 80
Complete trans 500
Drive shaft shortening less then 100
Wiring is mostly repining or buying an adapter harness 80-250 or free
Adding to wires to the pcm cost of plug 5 bucks and some wire
Cross member pushing it back and fabbing up on the center something to bolt the trans cost ?
If you say so... Please keep an honest record of cost as you go and document it well with pics here.
Old May 18, 2016 | 10:03 PM
rexmburns's Avatar
Super Moderator
I personally have no hands on experience with this company but in researching trans options for my truck I've done allot of reading and almost all of it wad positive 4L60E Monster-In-A-Box Transmission Rebuild Kits. $625 in parts and you can build a trans to handle 500 hp seems like a smart way to go to me. I'd personally opt for the converter as well. This is actually the exact route I will be going when it's time and it will be time cause my trans isn't happy about turning 40" tires lol!
For the lazy this is a breakdown of what the kit includes for $625
Mega Monster Rebuild Kit Includes:
Paper Gaskets
O-Rings
Lip Seals
Molded Piston - Quantity - 1
Sealing Rings
4L60E Corvette 2nd Gear Servo
Friction Clutch Plates (5-Low/Reverse, 4-Reverse Input, 5-Forward, 2-Overrun)
Steel Plates (5-Low/Reverse, 4-Reverse Input, 5-Forward, 2-Overrun)
3-4 High Performance Kolene Steel Kit - Quantity - 6
3-4 High Performance Clutch Kit - Quantity - 6
4L60E Filter
4L60E Heavy Duty Kevlar Band
Teflon Pump Bushing
Delco Front Seal Retainer Clip
4L60E Superior Shift Reprogramming Kit
Hardened Pump Rings
4L60E 10 Vane Rotor Gear
4L60E 10 Vane Rotor Guide
4L60E 10 Vane High Rev Kit
Heavy Duty "Beast" Sun Shell
Heavy Duty 29 Element Sprag
Heavy Duty Wide Rear Sprag
New Electronics Included
1-2 Shift Solenoid
2-3 Shift Solenoid
Manifold Switch
EPC Motor
3-2 Solenoid
PWM Solenoid
TCC Solenoid with Harness
Old May 18, 2016 | 10:04 PM
I will Iam also working on a 94 Honda accord and swapping a jdm motor and trans nothing fancy just replacements.I'll be starting trans my 4L80E swap next month after I figure out the cross member cost or deal I've been at this for a month.
Old May 18, 2016 | 10:07 PM
I bet it's not 40's on a blazer and I thought I was crazy for wanting a 4l80e lol.
Old May 18, 2016 | 10:08 PM
rexmburns's Avatar
Super Moderator
The crossmember is the easiest part of this whole thing IMO.
And I did see the monster in a box check out the specs the have on the stock 4l80e it's there fault Iam going at this.
Old May 18, 2016 | 10:14 PM
I hope it is easy on my wallet I have all the rest almost figured out if GM did the combo on in the silverado 2500 and 3500 and also in the Chevy express 2500 and 3500,Why not a guy with a heavy right foot.
Old May 18, 2016 | 10:16 PM
rexmburns's Avatar
Super Moderator
Like I said please keep a log of every dime you spend along the way and include any time you put in or labor you pay for I really do want to see what this costs in the end. I personally wouldn't ever do it but that don't mean I ain't interested!
Old May 18, 2016 | 11:35 PM
I know that on 4x4 s10 it's a bit more complicated but I will keep a log and pics.I'll be back with an update soon.
Xenon
Feb 24, 2021 06:18 PM
hivolts
Jul 25, 2011 09:17 PM
XxIRISH63xX
Jan 25, 2011 08:29 AM
ReignVictorious
Jan 7, 2010 11:07 AM
dennis65gt
Nov 9, 2009 06:25 PM
