Automatic Transmission 1997 Chevy Blazer
Old Mar 9, 2009 | 02:59 PM
ReignVictorious's Avatar
ReignVictorious is on a distinguished road
Unhappy Automatic Transmission 1997 Chevy Blazer
After driving 1 mile my car won't move in any gear until u restart again but the same problem happens again. Checked the fluid level which is alright but kind of smelly so guess need to change the oil and filter but any answer would help me pls...thanks
Sincerely,
Jatin
Old Mar 9, 2009 | 03:35 PM
Sounds like something electrical due to the aspect that if you restart, it will go another mile. Not much else to go on though... I will look and see if anything pops up in my references based on your description of the problem, but I doubt it.
Old Mar 9, 2009 | 05:17 PM
it would be great help...people telling me that I need to change my transmission....but I don't think so..it still drive in every gear but after 1 mile it stop none of the gear works while changing..I accelerate but still no move
Old Mar 9, 2009 | 09:12 PM
If this truly is something electrical, it looks like the only thing that could impact everything would be the Pressure Control Solenoid, but that is as much as I can find. There is nothing that is exactly like your problem...
Old Jan 7, 2010 | 08:31 AM
ChevyMan2010's Avatar
ChevyMan2010 is on a distinguished road
I'm not expert on these trans by any means, but after two days of making calls to local trans shops around my area about issues with my trans, one possibility could be this. Something came loose in the trans (Whether it's just gunk build up, or worst case, metal/parts) and found it's way into the filter. With your filter clogged, you will encounter issues, However when you shut the vehicle off, there could be just enough backflow pressure to "unclog" whatever's blocking fluid flow to your filter. When you restart, and try to engage the trans again, whatever had blocked the filter once again found its way back into the filter, thus creating problems for you a little ways down the road... Just a thought as to one possibility...
Old Jan 7, 2010 | 08:42 AM
rriddle3's Avatar
Since this thread is almost 1 year old and the OP has not posted since then, I doubt if he is still around.
Old Jan 7, 2010 | 11:07 AM
Yeah, rriddle you bring up a good point... I didn't notice the date until after I posted though... My bad... Lol
Jake--Blazer
Feb 7, 2016 03:07 PM
RickBlazer
May 26, 2010 04:33 PM
Supercity
Mar 16, 2010 04:39 AM
vindy78
Sep 22, 2009 04:17 PM
RA
Jul 10, 2009 01:09 AM
