97 Blazer 4 door fuel lines
Old Aug 16, 2015 | 11:00 AM
Red Sled's Avatar
Red Sled is on a distinguished road
I have a gas leak and am going to replace both the feed and return lines. Are these lines the same for both a 2 door and 4 door???? Thanks in advance
Dorman # 800-903 feed line some places say yes some say no???? All of the 800-905 return line say no????
Maybe a 5/16 patch is the way to go then??????
I see I should have put this in the General Help Tech
Old Aug 16, 2015 | 10:46 PM
800-903 is the pressure line, (3/8")
800-905 is the return line, (5/16")
Both part numbers are for 2 door models only.
Old Aug 16, 2015 | 10:58 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
I replaced my Master cylinder to rear caliper line (drivers side over frame rail) for $50.00 in parts with enough left over to do another ! A good source for tubing if you are doing it yourself is American Grease Stick Co. Poly-Armour® « Product Categories « AGS Company
Old Aug 17, 2015 | 04:39 AM
Red Sled's Avatar
Thank you sir!!!! Patch it is
Old Aug 21, 2015 | 04:30 AM
Red Sled's Avatar
.Put on Fuel injection rubber hose with double clamps on both ends Quick easy fix!!!
Old Aug 21, 2015 | 10:15 AM
I'm glad too see you are roadworthy again ! Or off-roadworthy !
Big Eazy
Apr 27, 2013 12:48 PM
skid9832004
Jun 5, 2011 01:38 PM
dj00140
Apr 13, 2011 10:48 PM
biglfla
Mar 24, 2011 06:19 AM
