97 blazer 4x4 won't get to operating temp unless a/c is on and then runs hot
Old Jul 19, 2018 | 10:09 AM
97blazerDad's Avatar
97blazerDad is on a distinguished road
Default 97 blazer 4x4 won't get to operating temp unless a/c is on and then runs hot
Ok, I have been racking by brain over this. Changed my thermostat a few months ago and ever since I can't get the engine up to normal operating temp unless the ac is on. Shortly after it gets there, it starts to get too hot....
I have tried burping the system several times, without the ac it stays cold, with it on it overheats. Fan clutch is a suspect, as well as the tstat being faulty considering I used a "failsafe" before I found out blazers do not like them. Anyone else ever experience this issue!? Ive never had a problem with both too cold and too hot at the same time. So confused that i dont even know where to start.
Old Jul 23, 2018 | 08:56 PM
Not trying to insult you, but you did put the thermostat in right side up, right?
Old Jul 24, 2018 | 08:03 AM
I'm pretty sure it's in there correctly. Unless the one I removed was in wrong....ive changed quite a few tstats and never thought about the person before me working on the vehicle.
Old Jul 24, 2018 | 08:06 AM
The spring should be on the bottom. If you aren't sure, you might want to drain the coolant, pull off the upper hose, and check.
Old Jul 24, 2018 | 08:09 AM
I plan on working on it today. Checked coolant the other day and the system really needs a flush. There is a good bit of what appears to be rust in it.
Scorpious
Jan 24, 2012 03:13 PM
95Jimmy
Oct 19, 2009 06:41 PM
95BlackBetty
Nov 11, 2008 09:49 PM
jman_08
Aug 13, 2008 03:54 PM
naf821
Aug 8, 2007 07:19 AM
