97 blazer AWD random misfire/hesitation around 2000 RPMs?
Old Apr 7, 2011 | 06:53 PM
sh4d0w1021's Avatar
sh4d0w1021 is on a distinguished road
Angry 97 blazer AWD random misfire/hesitation around 2000 RPMs?
have been working on my 97 AWD blazer for 2 weeks trying to find a solution to this problem.
after the vehicle sits for a few hours and it is humid out it misfires on random cylinders.
symtoms:
only happens between 1800 and 3000 rpms
only happens if it is humid/wet
stops after 15 mins of driving
sometimes it seems the throttle is unresponsive
what i have tried:
changed plugs,wires,cap,rotor,coil,vacuum lines
tested tps with oscilloscope
unplugged MAF problem persisted
cleaned injectors
added fuel additives
checked fuel pressure
sometimes i get a p0300 random misfire code but rarely
the more load on the vehicle the worse the misfire is. it will still misfire at 2000 rpms even in neutral
Old Apr 8, 2011 | 09:47 AM
sh4d0w1021's Avatar
could this be a crankshaft position sensor or a distributor?
Old Apr 8, 2011 | 10:52 AM
sh4d0w1021's Avatar
i changed the crankshaft position sensor and the problem still persists. i really love my blazer but this problem is rather annoying.
Old Apr 10, 2011 | 02:29 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Theory, if you unplugged the MAF sensor and the problem persisted.....did it throw a code for the MAF when you did this? Just saying it would make things worse if it was working right, just a thought. If the computer, for some unknown reason, is using stored data instead of sensor data that could be why it's giving you frits when it is humid out. Another possibility is your O2 sensors. Sometimes when they start to go bad they "hang up" on one voltage reading, making fuel delivery not adequate for what you are trying to do (aka test O2 sensor(s)) Also ohm out your ignition coil, it sounds like your not getting a hot enough spark because, after you drive it a bit it seems better (except under heavy loads)
Your CPS does nothing more then tell your vehicle when to start, usually when cyl 1 is TDC so if it's working your truck will start.
Old Apr 10, 2011 | 10:47 PM
sh4d0w1021's Avatar
Thumbs up
after some reading i decided to investigate the ignition control module tho i was told by many people (not in this forum) that it was most likely not the cause. so first i removed the old 1 and cleaned the plug and the module with electric contact cleaner and left it set for 10 mins. then i noticed the thermal compound was hardened up so i cleaned the surfaces with steel wool and applied new compound. fired it up and it ran worse than b4. so i went to autozone and tested the module and it failed. so i replaced the module and boom! problem solved! runs better than it ever has . so if anyone else is having a random misfire code and getting extreme hesitation/misfires almost to the point of engine stalls especially when it rains definitely look into ignition control module replacement. i hope this post helps people who have similar issues. thanks to everyone that helped me out.
Old May 12, 2011 | 10:13 AM
dirty420's Avatar
dirty420 is on a distinguished road
thanks for the post . im having those same problems pretty much . im going to look in to that for sure
sputtle
Apr 20, 2014 04:46 PM
rrk03300
Nov 15, 2012 10:29 PM
2000jimmbo4x4
Jun 12, 2011 12:47 PM
Magman
Nov 16, 2010 11:57 AM
SHA-BOOM280
Nov 18, 2009 01:41 PM
