Anyone ever figure out the hesitation between 1500 and 2500 rpms
Old Jun 11, 2011 | 07:18 AM
2000jimmbo4x4's Avatar
2000jimmbo4x4 is on a distinguished road
Default Anyone ever figure out the hesitation between 1500 and 2500 rpms
just as the title says? me and several other of my blazer buddies have an issue with a hesiation under load anywere between 1500 to like 2300 rpms. the engine overcomes this pretty easily. its just annoying having the engine hit a flat spot while your climing a hill. the only time this dosnt happen it seems is at WOT.
Old Jun 11, 2011 | 10:18 AM
TSB # 03-06-01-024 describes a situation where the torsional vibration of the balance shaft could cause the knock sensor to think it detects detonation which would then cause the PCM to pull timing. I would get a hold of a scan tool capable of displaying the knock sensor active count and see if it isn't increasing while under load in this RPM range.
Old Jun 12, 2011 | 12:47 PM
i know the parts list shows an oil pan gasket. do you know iff this is just a new front piece or a whole gasket. i dont really feel like dropping the diff again. i will take a look at the sensor readout on monday. that dose make sense though. to bad its not a recall.... thanks for the info
chevyblazer9588
Aug 5, 2011 08:44 PM
sh4d0w1021
May 12, 2011 10:13 AM
PaulO2288
Nov 1, 2010 06:10 PM
pctechdude
Jan 11, 2010 07:08 AM
jamez70
Sep 4, 2009 01:13 AM
