97 blazer fly wheel visable from under car
Old Mar 27, 2010 | 02:11 AM
darque's Avatar
darque is on a distinguished road
Default 97 blazer fly wheel visable from under car
looking at the car from the underbelly, i see a 4-6 inch perfect circle opening (factory) at the rear of the motor where it meets the transmission... this opening seems odd... i can see the spinning flywheel as clear as day... is this normal
or did that part fall to its death ? ?it so what is the part ?
Old Mar 27, 2010 | 06:37 AM
There should be a cover over that inspection hole.
Old Mar 27, 2010 | 08:51 AM
paveland's Avatar
paveland is on a distinguished road
Ditto. Sounds like your inspection covefr fell off, usually held on by 4 bolts. I would look for it or get a new one relatively soon since now there is a bunch of road muck gumming up your flywheel and making your clutch and flywheel dirty.
Old Mar 27, 2010 | 10:34 AM
LuvMyTJ's Avatar
Snag one from the local junkyard. They can be plastic or metal. Usually they have about 4 bolts holding them on. Only takes a few minutes to install.
Old Mar 29, 2010 | 09:56 PM
Brandon43's Avatar
Brandon43 is on a distinguished road
I noticed mine has the cover missing too. It's been like that for probably 20,000 miles. Bad? Any damage?
Old Mar 30, 2010 | 05:36 PM
paveland's Avatar
It shouldn't cause any immediate damage as long as your keep out of alot of dirt/mud/rocks and general muck. But I would definetly get one back on there since you will probably shorten the life of the clutch, flywheel, flexplate, etc........ and its not hard at all to fix probably just hard to find.
Old Mar 31, 2010 | 02:03 PM
Brandon43's Avatar
You are very right there. I went to the auto junk yard and could not find any covers. Might try Ebay.
Old Mar 31, 2010 | 03:08 PM
oktain's Avatar
if all else fails... give the dealer your VIN and they'll order you the part.
Old Mar 31, 2010 | 05:57 PM
abig84's Avatar
I ran with out one for about 4 years in a offroad truck never no problems. Had a few sticks go up there and make a bunch of noise but no leaks ore anything.
Matt77
Jun 25, 2014 12:21 PM
supermario28
Mar 29, 2014 11:21 PM
JPate
Feb 2, 2010 06:40 AM
harleyowner
Dec 30, 2009 06:16 AM
skitzobmxr
Feb 26, 2007 11:13 PM
