97 rear main seal
Old Apr 1, 2008 | 07:51 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default 97 rear main seal
97' 4.3 LTR. 4X4, 142K Miles. Have the old little puddle of oil on the concrete, underneaththe rear of themotor after I pull in the garage for the night. I've read some posts on this and I will check the pan bolts. Is this a common problem with these vehicles?Question I have is.......is there enough room to pull the trans. back from the motor to get at the seal? I do not feel like pulling the motor out. Any other tips on this project would be appreciated, thanks.
Old Apr 1, 2008 | 11:25 PM
Hanr3's Avatar
Default RE: 97 rear main seal
I know there is enough room to slide the tranny back far enough to get the flexplate off. I used 4 long bolts to replace the regular tranny bellhousing bolts. Disconnect what I had to and slide the tranny back to replace a cracked flexplate. Once the flexplate is out, then you can access the rear main seal. I haven't replace one of those yet so I got no info on that part of your question.
Its a lot of work, verify your oil isn't coming from somehere else first, like the backside of the intake manifold. They ahve been known to leak at the intake manifold gasket. I guess the eaasiest way to tell is if the oil is inside the bellhousing or outside the bell housing.
ebristol
Apr 1, 2008 04:53 PM
piggyb00
Feb 6, 2008 08:46 AM
MikeD
Engine & Internal
Mar 3, 2007 11:24 PM
FImports
Dec 13, 2006 03:00 PM
smitty
Aug 12, 2005 11:38 PM
