97 Rocker Valve Adjustment
Old Jul 7, 2017 | 08:21 AM
  #131
ChuckNTruck's Avatar
Originally Posted by Tynan Tha Real Dill
OK I bought the 1995 GMC Jimmy 4.3 262CBI Vortec. The bad :
1. Reverse is out, it jumps into gear but doesn't move backwards.
2. Bad acceleration, I can hold gas pedal to the floor and go no where, until I pump it then it will slowly gain acceleration. Jumps thru gears with no problem. Took it on the highway home last night, got several miles @ 55mph and the passengers side under the truck started smoking. Jumped off the highway to main streets @ 25-35mph, and it stopped smoking and still continued to shift fine, when it could due to slow acceralation. Idles @ 500-700 rpms. Sometimes "pops" when I try to accelerate it. As I'm accelerated, and I'm coming to a stop, I can hear a rattling noise as I stop.
Those are my 2 only problems. I'm guessing fuel filter replacement, transmission filter replacement, new tranny fluid , new spark plugs, and an oil change? Truck has 190k on it. Engine fires up and idles fine, until I try to accelerate and drive. Drivable, just takes some pumps to get it going.
Automatic transmission loosing a gear usually means a rebuild or replacement is in your future. You can try changing the fluid and filter but dont be surprised if there is no difference. It could be alot of things causing the bad acceleration. Where was the smoke coming from? Front tire, Under truck, engine compartment? Does the blazer roll fine in neutral?
Old Jul 7, 2017 | 08:32 AM
  #132
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
OK. Under truck, passenger side is where the smoke comes from. And no, it's hard to push while it's in neutral, like the E brake is on.
Old Jul 7, 2017 | 09:16 AM
  #133
newguy's Avatar
sounds like a plugged cat to me , easy fix. Start it and run it a bit , the cat will be really really hot if not glowing red
Old Jul 7, 2017 | 10:09 AM
  #134
Here are pics of it...
Attached Thumbnails 97 Rocker Valve Adjustment-20170707_095918.jpg   97 Rocker Valve Adjustment-20170707_095954.jpg
Old Jul 7, 2017 | 10:29 AM
  #135
newguy's Avatar
the filter material in it will get loose, fall apart causing the rattle. it will also clog it up not letting exhaust through it causing sluggish engine performance. you cant tell from the outside
Old Jul 7, 2017 | 11:35 AM
  #136
How can I test it or remove it? A friend of mine said I don't even need it, and O'Reilly has pipe to put in place of the cat and not cause it to be loud? Do I have to have it on or can I drive without it?
Also why is it hard to push when it's in neutral without the E brake?
Old Jul 7, 2017 | 11:41 AM
  #137
Thats exactly what i was thinking. If it rolls easy in neutral than it sounds like it could be a clogged Catalytic converter.
Unless you have a Infrared thermometer or temp gun i would suggest taking it to an exhaust shop and see if they will test the cat for you. The simple way to test the cat is to measure the temp of the exhaust pipe just before and just after the Cat. If the temperature after the cat is hotter than before the cat it is working correctly but if the pre cat temps are the same or higher than the post cat temps then the Cat is probably bad.
Old Jul 7, 2017 | 11:45 AM
  #138
If you take the cat off and just replace it with a pipe, it will throw a check engine light for the emissions system.
In the previous post you said it wasnt hard to push in neutral. If it is hard to push, i would try jacking the front end off the ground and spinning each wheel to make sure they turn freely. Then chock or block the front tires, jack up the back end and put it in neutral with the e-brake off to make sure the rear spins freely.
Old Jul 7, 2017 | 12:58 PM
  #139
What does it mean if it doesn't spin freely or it's hard to spin?
Old Jul 7, 2017 | 01:16 PM
  #140
Depends on which tire. If it is one of the front it could be a collapsed brake hose or stuck brake caliper dragging. If it is one of the back it will depend if you have disk or drum brakes. Drum brakes could be collapsed brake hose, just out of adjustment or e-brake not releasing completely. and disk brakes could be stuck caliper or collapsed brake hose or e-brake not releasing completely.
By spin freely i mean it is not hard to turn by hand.
If it was just one of the front brakes dragging though it would pull real hard to one side while you are driving. Is the truck pulling to either side when you drive it?
