97 Running a bit rough
The truck was staling out a few days ago. I had a new Cat put on it, and it hasn't stalled since, but it still doesnt seem to be running quiet right., seems sluggish. Is there any immediate things I should be looking at? The only codes I am getting are an EVAP code cause my case cap refuses to seal (even after being replaced), and a transmission code cause my Solenoid is going bad. I have already cleaned my MAF, EGR, and Throttle body since having the Cat installed, and I am out of ideas.
Secondly, regarding the Trans. Solenoid, is this a hard thing to do? I have a fair amount of experience working on cars, but I am far from a whiz mechanic. And is this something that needs ro be dealt with asap? The truck seems to shift fine 90% of the time, but does sometimes jerk when shifting. Thanks for any info you all might have. I will continue my search through other posts for a solution, just didn't want to start replacing things that weren't necessary.~Brian
Note: My "Service engine soon" light only seems to come on when I am at 3/4 or less for fuel. (not sure if that means anything)
I've not yet figured out what is going on with the truck yet. It's been a week since the new Cat, and it still has NOT stalled. It IS still running a bit sluggish. I'm not sure what it is suppose to idol at, but it sits at 500 when I am in drive, and it just seems like that is too low, and it has to "wake itself" up when I hit the gas. I have 3 upgrades on the horizon.
1. CAI from Spectre
2. Cherry Bomb Turbo
3. New Fuel injection (still no clue what to get here)
Any advise on what I might want to do first? Or is it not really going to matter. I will be doing them 1/month, and I am hoping my problem will be solved by replacing one of said systems. Even if it doesn't fix the problem I don't feel I will be out of money since I wanted to do these upgrades anyways. Does my plan sound logical?
1. CAI from Spectre
Dadatone
Jul 26, 2012 12:28 PM
a_tack
Sep 14, 2007 04:26 AM
