'97 S10 4.3 Liter - Got spark, got fuel, turns over - won't start!
Old Oct 28, 2012 | 08:14 AM
  #21
dave39's Avatar
dave39 is on a distinguished road
Originally Posted by phandango
anyone ever heard of collapsed rings or a broken cam shaft due to overheating? I'm going to check compression on all cylinders (except no. 3, which is behind the steering rod). I was talking to a mechanic who was in the parts store tonight. He said the 4.3 liters along with some other motors like subarus, don't hold up well when overheated. The above-mentioned symptoms are the result when over heated. There's also the possibility that if the camshaft breaks, compression will show normal on a few of the cylinders, but nothing on others (front of motor vs. Back).
the cmpression should be no more than 10 percent difference in any cylinder higher or lower anything more or less rebuikd
Old Oct 28, 2012 | 08:28 AM
  #22
dave39's Avatar
check 3 by putting a spark plug socket on by hand then get box wrench on back side of socket comes out easy, put back in by hand with socket tighten back up with box wrench easy and i highly doubt you broke your cam from overheating doing this for 25 yrs never seen that happen. Blown head gaskets happen first and youd know this right away as all compression would be low. If your compression in all cylinders is less than 10 percent difference then motor is good. Youy antifreeze is not mixed with your oil then 90 percent sure didnt blow head gasket. Sounds like the mechanic that hyad this truck didnt know his *** from his job. I think it will come down to distributor or wires not right in correct order on motor or distributor cap or the distributor was moved a tooth or so off. Had this problem i changed distibutor and made sure wires were correct on motor and on cap as well as rotor and cap beeing put on right possition
Old Oct 28, 2012 | 08:49 AM
  #23
dave39's Avatar
so, here's something interesting. It appears that the mechanic who looked at this before i bought it drained the coolant from it. Would no coolant in it cause a no-start situation? Additionally, it appears that the thermostat is stuck wide-open. He did say the thing overheated when it stopped running.
he drained it for a reason so that it didnt mix with the oil he new it had a blown head gasket or assumed it did cause the first thing i check is oil is it clean is antifreeze mixed in it. The most common failure to any vehicle all when overheating is head gasket they crack they also crack heads and blocks did you fill it probably the problem is its got to run and have pressure in the engine for you to truely know if antifreeze is leaking into oil or pouring out the head or block that could be cracked the only reason for this so called mechanic to empty it would be to mislead someone by not knowing the extent of the overheating. And so you wouldnt notice mixed oil and antifreeze or leaks from cracked heads or engine block. The main concern would be geting a compression test on all 6 cylinders at least the 5 you can get to easily and if that checks out then im saying its something to do with cap rotor or distributor. Driver side 1,3,5 pass side 2,4,6 front to back cap is numbered also follow one on cap on side mount caps be careful following tabfrom cap top to inside tab if the rotor is at 7-8 oclock possition and the tab inside cap lines up thats good if not your off 180 degrees if its pointing at 6 rotor is on backwards. Make sure to tdc the engine before checking DISTRIBUTOR tdc timimg marks on harmonic balancer will point to 0 on gauge in front lower motor behind the harmonic balancer. IF YOU WANT 3 OUT ITS SIMPLE TAKE A SPARK PLUG SOCKET AND PUT IOT ON 3 BY HAND THEN GET A BOX WRENCH ON THE END OF THE SOCKET THE BOX WRENCH IS TURNING SIDEWAYS WHICH PARRALEL WITH COLUNM ELIMINATES TAKING STERRING COLUNM **** AND GEARBOX OFF I GAURANTEE THIS IVE DONE IT MANY TIMES WHEN YOU PUT IT BACK STUFF PLUG IN SOCKET START BY HAND THEN USE BOX WRENCH TO FINISH TIGHTENNING IT THERE ALWAYS A TRICK TO SAVE YOUR SANITY.
Old Sep 8, 2013 | 04:26 PM
  #24
Phandango's Avatar
Phandango is on a distinguished road
Default Back at it
Well, I let it sit for a while and am back at it. I pulled off the distributor cap and everything looks correct. Tab is between 7 and 8 O'Clock. While Turner ng the engine with a wrench, I felt NO COMPRESSION. I tested all holes and they're all dead. So, unless I find a new motor on CL locally for cheap, I'll be rebuilding it. Anything I should know before going into it? I've rebuilt motors before but am looking to do the least amount possible here. Maybe go in from the bottom on an engine stand and replace the rings. Is this wise? Any recommendations or thoughts are appreciated. Thanks in advance!
Old Nov 21, 2019 | 09:27 PM
  #25
Brooklyn Knight's Avatar
Brooklyn Knight is on a distinguished road
Originally Posted by Phandango
So I'm going to heed the last responder's advice and check the ignition switch. I don't have the money to throw parts at it until it starts, though I wish I did. One thing that has me curious that it may be the ignition switch is that the headlights don't completely turn off unless the key is turned off. They stay on dim (less than low-beam brightness) even when the light switch is turned off. I understand this also may be the headlight switch itself, or even the relay, but if it is the ignition switch causing this, could it be possible that it's causing the vehicle not to start, too?
The reason for the headlights being dim is that the lighting system has DRL (Daytime Running Lights). It will turn the headlights on at reduced voltage. To bypass this while servicing the truck, you have to put the parking brake on. To bypass the DRL feature all together, just pull out the fuse for the DRL.
Old Nov 21, 2019 | 09:35 PM
  #26
Originally Posted by dave39
negative get spark plug socket slide on 3 plug then get a box wrench on the back side of the socket comes out like butter no needv for insanity
Or just get a swivel spark plug socket.
Old Nov 22, 2019 | 07:22 AM
  #27
LesMyer's Avatar
You do realize this thread is over 6 years old...….. time to retire it.
Sam Quillen
Jul 27, 2015 12:27 PM
monkey36
Sep 14, 2011 11:46 PM
88blaz4.3
Aug 21, 2011 11:16 PM
Quicksilver
Jan 13, 2011 11:40 AM
fjdavid
Aug 16, 2007 07:32 AM
