98 4.3vortec fresh parts build, got a few questions.
Old Aug 16, 2015 | 09:06 AM
aksallday's Avatar
aksallday is an unknown quantity at this point
Default 98 4.3vortec fresh parts build, got a few questions.
So our 98 4.3 vortec dropped oil pressure and started knocking on the highway doing 60 while she was driving to her grandma's.
I got it yanked and disassembled, it had spun 2 rod bearings and wore out the 2 sets of inner main bearings.
Took it to the machinist fee weks ago. he surfaced and worked the rods and caps, shot peened them, pistons were reinstalled.
Cylinder one crank journal was trashed, 6 was worn but recondition able.
Mains were fine and a new CSS Stroker crank was ordered, along with a Profiled cam from CSS
Ive got everything sitting here now and i am ready to re assemble, I've ran into a issue of how should I aling the cam and balancer, along with the crank shaft?
Old Aug 16, 2015 | 09:27 AM
WildDomesticTabby's Avatar
WildDomesticTabby is on a distinguished road
Dot on the balance shaft gear points down at 6'o clock. Dot on the camshaft gear points up at 12'o clock. Make sure that the dots on each gear are now facing each other.
Afterwards, you install the camshaft sprocket and the crank sprocket. Dot on the camshaft sprocket points down at 6'o clock. Dot on the crankshaft sprocket points up at 12'o clock. Make sure the dots on each sprocket are now facing each other. Now, without disturbing the timing, remove the camshaft sprocket and carefully install the timing chain along with the camshaft sprocket. Your motor is now properly timed.
Old Aug 16, 2015 | 10:45 AM
Red Sled's Avatar
Red Sled is on a distinguished road
Delete post
Old Aug 16, 2015 | 12:06 PM
aksallday's Avatar
Awesome!!!!! Thanks a lot wilddomestictabby, I searched the Chilton's, Haynes and my gm tech manual like crazy and couldn't find it, must have over looked it. Even searched Google and s10forum but couldn't couldn't find a definite answer. Love this forum, this group of people is as good as the Z32 community.,
Old Aug 16, 2015 | 01:57 PM
aksallday's Avatar
My other question is. In what orientation should the pin and or the two timing marks of my harmonic balancer be in, in relation to the key way shaft groove on the crank shaft balancer pulley?
I've rebuilt a 4.3 before, but the rotating assembly was use able so I had all my marks.
This time around I have no clue, because of the new crank and cam. Thats the reason for the questions lol. Plus I've been deep in the world of Z32's for a couple years so forgot a lot of vortex stuff.
Old Aug 16, 2015 | 05:16 PM
If I understand your question correctly, you want to know which direction timing marks on the harmonic balancer should face before pressing it in? If so, then it doesn't matter. The keyway groove on it only lets it go in one way.
If you'd like to set your ignition timing after installing everything, then you'd want to post the vintage of your truck. The late model ones don't have adjustable timing, other than a slight Crank Offset adjustment with a computer hooked up to monitor change.
Old Aug 16, 2015 | 09:28 PM
aksallday's Avatar
Im talking about the ring weight that goes on the crank pulley, that has the rubber gasket in between it and the pulley. Not the belt pulley, the crank pulley.
Old Aug 17, 2015 | 01:41 AM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
It sounds like your balancer is in two pieces and needs replacement.
Old Aug 17, 2015 | 08:35 AM
aksallday's Avatar
Yes! Except when I go to order a new one all I can find is just the crank pulley. Not both pieces already together.
Old Aug 21, 2015 | 08:37 AM
LesMyer's Avatar
So how does a stroker crank work with stock rods and stock pistons? Think about it. Longer stroke would push the pistons into the heads. Did the machinist check the line bore carefully - usually it is required when you rattle any main bearings. Better just buy a stock crank kit with bearings for the correct year engine - will a new aftermarket crank be balanced for your particular rods/pistons/balancer/flex plate? Why would a machinist install pistons and rods for you without the crankshaft? Forget performance cam - it won't be worth it. Harmonic balancers don't come in two pieces, that is why you can only find one peice. I'm sorry but it sounds like you should have the machinist order parts and put the engine together for you. Seriously! I predict you are heading towards a lot if incompatibility and inexperience problems - it's right on the verge of sounding like BS. I know that's not what you want to hear - but someone has to say it.
Blaze1Chef
Mar 7, 2021 10:44 AM
Bybsurfr32
Jun 2, 2019 04:00 AM
c1rca121
Dec 16, 2010 12:14 PM
zcat23
Sep 29, 2010 10:30 AM
Bybsurfr32
Nov 1, 2009 06:50 PM
