98 Blazer NO FIRE!
Old Apr 5, 2007 | 01:49 PM
jcork's Avatar
jcork is an unknown quantity at this point
Default 98 Blazer NO FIRE!
In the last year, new, fuel pump,filter, relay and transmission and water pump and plug plug wires and tires and brakes and ignition module,coil. Engine sputtered then stalled. Now no fire. I can crank it all day and no fire. code scan shows po 1351 ic circuit high/open. no spark out of coil but tested all connections to ignition module and coil and they have juice. Had a couple "mechanics" look at it and they are at a loss also. Please help!
OK, found out that the ic circuit is the ignition controll and is located in the distributer and these are known for going bad but could also be crankshaft sensor. Without buying parts, how do i determine witch is at fault?
Old Apr 6, 2007 | 02:39 PM
jcork's Avatar
Default RE: 98 Blazer NO FIRE!
after swapping out the pick up sensor and the crank sensor i started testing wires. i found i had power to a wire on top of coil but none coming out the plug. changed the plug and truck runs like a top again.
tall_ish
Nov 20, 2010 09:05 PM
mastergrader007
Nov 25, 2009 05:11 PM
daroach1
25
Jan 6, 2009 12:37 PM
scottyk
Feb 28, 2007 09:46 AM
dashyman
Jul 24, 2006 06:43 PM
