98 Blazer TPS only works in run position
My 98 blazer tps is only working with the key in the run position. While looking at it with my scan tool it works perfectly with out the engine running. When I start the engine it fluctuates around 3% and WOT only brings it up to around 9%. I have watched the scanner and wiggled all the wires and connections from the ECM to the TPS and didn't see any drops like I would for a shorted wire.
Any suggestions what would cause that, I'm leaning towards ecm failure.
nuwave
10-19-2011 11:16 AM
ltarcticwolf
06-22-2011 12:00 AM
YOURCONNEXX
10-21-2009 07:10 PM
muszyngr
05-28-2009 02:02 PM
