98 Blazer trans/gear ratio questions ????
Old Jun 6, 2010 | 04:53 PM
Demonspeed13's Avatar
Demonspeed13 is on a distinguished road
Default 98 Blazer trans/gear ratio questions ????
I just purchased a 98 LS 4 door Blazer and it has the p1780 code . I didn't know what it was and I still don't know much about it but I found another trans that I was told come out of a ZR2 but I'm not sure on year . My question is , is there a difference in the gear ratios ? I know mine has a 342 ratio because it has the original window sticker with it . If anyone could help me with this I would be grateful . Thanks
Old Jun 7, 2010 | 05:46 AM
ohsofly's Avatar
The gear ratio is in the differential(s), not the transmission. You just have to make sure its the right transmission, I beleive your truck would have a 4L60E - automatic transmission 4 speeds plus overdrive. The ZR2 should have the same transmission just have different gears and bigger tires.
Old Jun 7, 2010 | 07:48 AM
Thanks for the info . I knew the gears are in the diff , I just didn't know for sure if the gear ratios was different between the two . I know mine has the 342 , I kinda wish it had a 373 so maybe ill just change it all around . Thanks again
BRoss99
Oct 31, 2014 03:32 PM
p_m_clean
Feb 8, 2012 05:00 PM
dagda
Jan 12, 2010 06:37 PM
NC93BLAZERLT
Oct 28, 2008 07:52 AM
ceanern
Jun 17, 2006 08:44 PM
