98 chevy blazer 4x4 stuck in 4 lo
Old Sep 4, 2007 | 07:58 PM
treygen's Avatar
treygen is an unknown quantity at this point
Default 98 chevy blazer 4x4 stuck in 4 lo
I have a 98 chevy blazer i just replaced the engine and my 4x4 is stuck in 4 lo my tansfer case control mod is ok vacuum lines actuator im wodering if its my transfer case motor gone bad i have the 3 switches on dash but i cant change settings not even by putting blazer in neutral i just stays in 4 lo any ideas as to what is going on here please help!
hillbillyinOhio's Avatar
Default RE: 98 chevy blazer 4x4 stuck in 4 lo
did you check the fuse panel??
Old Sep 4, 2007 | 08:08 PM
Also, if you do not have Auto4WD, then you could go through the diagnostic trouble steps detailed in the OBD2 Non-Automatic Transfer Case Diagnostics. That should give you any codes that may be present.
stingray74
Mar 5, 2015 08:27 PM
rwgottar
Nov 24, 2013 08:33 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
paul43812
Dec 1, 2007 12:20 PM
