Need fuel feed line for 95 4.3 Vortec VIN W
Old Aug 6, 2007 | 06:09 PM
pinktruck's Avatar
pinktruck is an unknown quantity at this point
Default Need fuel feed line for 95 4.3 Vortec VIN W
Hi--this question is for a 95 S-10 with a W VIN code, Vortec 4.3. We need to replace the feed where from the main fuel line goes into the intake manifold at the back of the engine, under the injector unit (multi-port.) Does anyone know if this is an "available part, " or if it is something we have to make? It seems that most manuals don't include my particular engine, so we're having trouble identifying the part. It's sort of an "L" shaped thing, no connectors or anything, it just plugs into the main fuel line on one side, and the lower intake manifold on the other end. Thanks for any help.
Old Aug 6, 2007 | 07:26 PM
Default RE: Need fuel feed line for 95 4.3 Vortec VIN W
Are you talking about the internal lines inside the intake plenum? If so, this is commonly referred to as the 'nut kit'. Lindertech.com has these lines available as does many other sources.
Old Aug 7, 2007 | 08:44 PM
pinktruck's Avatar
Oh, you are an angel; thank you so much.
Old Sep 4, 2007 | 08:16 PM
treygen's Avatar
treygen is an unknown quantity at this point
Hello i just put an engine in my 98 chevy blazer and the fuel feed lines you are refering 2 are called fuel rails i have a pair you can get for $10.00 + sh
i can also send you a pic.
Old Sep 4, 2007 | 08:24 PM
Your '98 is an SCFI motor while the '95 in the original post is a CPI motor. Completely different fuel injection systems.
93S10TahoeLT
Apr 5, 2013 06:59 PM
95jblaze
Aug 27, 2011 03:46 PM
SlydinClyde
Oct 18, 2009 08:14 PM
BlazerSS
Engine & Internal
Apr 21, 2007 03:44 PM
