99 4.3 vortec cutting out?
Old Aug 4, 2009 | 05:18 PM
ChevyBlazer1989's Avatar
ChevyBlazer1989 is an unknown quantity at this point
Angry 99 4.3 vortec cutting out?
ok my blazer seems to be cutting out from 2000 to 3000 rpm.. I have replaced plugs, cap, rotor, coil.. The previous owner had the cat cut off but it just started doing it. Idk wat the problem is.. Anybody know where i should try now?
Old Aug 4, 2009 | 05:24 PM
rriddle3's Avatar
Have you changed the fuel filter and cleaned the EGR valve? Also, you might use the 96+ Fuel System Diagnosis.
Old Aug 4, 2009 | 10:55 PM
redblzr4x4's Avatar
redblzr4x4 is on a distinguished road
Default i had the same problem!!
my blazer would do that too, from 3000 rpm on up it would sputter nasty. i changed the coil and Ignition control module mounted with the coil. It worked... seems to pick up a lot faster
Old Aug 5, 2009 | 07:59 PM
poohmom0703's Avatar
poohmom0703 is on a distinguished road
Had the same problem about a year ago. Shop told me that model doesn't like generic parts and had to replace all of mentioned and the fuel pump.
adam.lee.person
Aug 11, 2008 07:43 AM
justDrivin
Apr 7, 2008 06:13 PM
Blazerx85
Nov 8, 2007 06:13 PM
RCarp48
Apr 30, 2007 12:59 PM
xtreme01blzr
Oct 18, 2006 03:23 AM
