99 4x4 blazer transmission problems
Old Mar 14, 2011 | 10:00 PM
KrazieRuskie's Avatar
KrazieRuskie is on a distinguished road
Default 99 4x4 blazer transmission problems
I need some help diagnosing my transmission problem. It all started whilst I was driving home one night going around 80kms and then I can hear my engine rev but it continues to slow down until I reach about 30kms and then it grabs again. I have to continue at a low speed or the transmission will slip again and I had to crawl home at one point it wouldn't even move for me so I waited and eventually it would again. The next day I tried putting it in gear and it was able to move again I drove about 150 yards and then it completely stopped working again I waited a few hours and I was able to drive it back into my driveway, but no further. I have not attempted to move it again. The fluid is red and at the right level. I am wondering if I need a rebuild or if there is some other small problem that can be easily fixed? Your time and help is much appreciated!
Old Mar 14, 2011 | 11:10 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Hard to tell. If you know anyone with transmission experience locally, I'd give them a call.
It will make it through 1st and 2nd gears, but then slip after? That's the 3-4 clutches gone(common).
However if the fluid is still red... at least on the dipstick. It may be a leak in a seal. A leak in the forward apply circuit would cause issues.
I would start out by checking the A+B shift solenoids (search). While you're at it, go through the electrical system and check for low voltage. i.e. Battery, alternator, transmission harness, ECM connections.
You also may want to locate a scan tool that will give you a readout of sensor status. I put up a post that listed at least 6 sensors that affect transmission shift points and fluid pressure control. Any of those could be suspect as well. It's better to do some research before throwing away $500-$2000 on a transmission when you end up paying for something different later.
Jacob Bo
May 16, 2015 10:48 PM
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
upblazer95
Apr 4, 2009 08:27 PM
sfesenko
Nov 30, 2008 08:55 PM
vtlew
Jun 23, 2006 09:13 PM
