99 blazer y pipe removal
Old Aug 18, 2011 | 12:33 AM
karmtec's Avatar
karmtec is on a distinguished road
Default 99 blazer y pipe removal
So my transmission is officially gone so I am pulling it off and replacing with used or rebuilt one...
can it be done without removing the y-pipe? These bolts seem extremely stuck. They are soaked daily for a week with pb blaster and I am thinking of getting a mapp torch but i am still afraid to break a stud.
if a I break the nut/stud off the y-pipe to manifold bolt, do people normally drill these out on the vehicle or start taking off the manifold then?
Old Aug 18, 2011 | 07:28 AM
You are going to have a very hard time removing the trans without removing the y-pipe. There just isn't enough room without removing it.
Heat will help greatly, but the kind of heat you need doesn't come from even a MAP gas plumbing torch. You'll need oxy-acetalene. The trick is getting the heat into the nut really fast so as to limit the amount of heat transmitted into the stud.
If you snap one off, you could try removing it with the manifold in the truck, but that can be an exercise in frustration.
Old Aug 18, 2011 | 08:59 AM
karmtec's Avatar
Do you know if the bolts in question are pressed or screwed in? If they are pressed, can they be hammered out?
will the manifold to head bolts probably also be seized?
Old Aug 18, 2011 | 09:36 AM
They are threaded in to the exhaust manifold.
Old Aug 20, 2011 | 04:28 PM
MonkeyGein's Avatar
MonkeyGein is on a distinguished road
i asked the same question. i used a craftsmans bolt/nut remover for stripped nuts and a cheapy 12v impact and replaced the nuts on the mani - ypipe. on the back end i broke them off as they were that bad and just had the studs drilled out and put in bolts. i had trouble drilling out the bolts on another one of my cars so i just used a griner and went at iut from the side. with 3 like on the blazer in that senario it won't come apart
Old Aug 23, 2011 | 11:34 PM
karmtec's Avatar
Using an oxy-acetylene torch, I still managed to break 1 bolt on the y-pipe to cat connection.
Are these pressed in as well or threaded? Any hope for an air hammer or does one usually drill these out? (the broken one is on bottom and will have about 1/4" of threaded bolt protruding once y-pipe is removed).
Old Aug 24, 2011 | 06:10 AM
dmon901's Avatar
dmon901 is on a distinguished road
You got all the hard nuts off already. I would slice the bottom at a 90 degree angle with a whiz wheel. Grind right through the stud. It will collapse with vise grips and turn out. Pop s new 3/8 bolt and a few fender washers in its place and you should be golden
Old Aug 24, 2011 | 12:32 PM
karmtec's Avatar
So split the button pointed to by the arrow as deep as I can get with a die grinder? Then use vice grips on stud?
Old Nov 14, 2014 | 08:41 PM
TMM217's Avatar
TMM217 is on a distinguished road
Just started this project today. The left side nuts came off ok. Now the right side is giving me hell. Been soaking with wd40. The nut on inner broke loose and nut on right towards wheel well is rounding. How do you get to the upper nut with cat in way. It's sucks I'm down to 2 lousy nuts. The left side had me confident this was going to work out well, guess not.
Old Nov 16, 2014 | 06:57 PM
TMM217's Avatar
Just an update. http://www.irwin.com/tools/screw-bol...-deep-well-set
Found these at Auto Zone. These are a miracle. Removed the 2 toughest nuts to remove with ease and no slipping. They have great grip. So guess I was right with them coming off.
So no heat required in my case.
gtmccormick
May 14, 2015 01:31 PM
flipzat
Dec 19, 2009 09:40 PM
gscrippler
Headers, Intake, & Exhaust
Sep 14, 2009 09:35 AM
marksoftball
Dec 29, 2008 08:27 PM
johnnyblaze
Sep 24, 2006 11:32 PM
