99 LS Blazer timming
Old Apr 15, 2018 | 04:12 AM
MadMerritt's Avatar
MadMerritt is on a distinguished road
Default 99 LS Blazer timming
Gday all
How do i check the timming on my 4.3ltr Blazer? Do i set it like a normal engine or is it computer controlled?
All advice is hugely appreciated
Old Apr 15, 2018 | 05:53 AM
newguy's Avatar
All timing is computer controlled, It cant be advanced. You need a high end scanner to do a crank position relearn if needed, that is basically adjusting your timing then do a camshaft position set Which adj. rotor to contacts on the cap.
Old Apr 15, 2018 | 05:58 AM
MadMerritt's Avatar
Oh ok, well that sucks...
i know not to play with it now hahaha
Old Apr 15, 2018 | 06:15 AM
newguy's Avatar
Yes, dont move anything with the dist. You`ll create misfires
Juss11
Aug 12, 2012 02:49 PM
