99 mass air flow
Old Nov 24, 2013 | 09:04 PM
beast1978's Avatar
beast1978 is on a distinguished road
Default 99 mass air flow
Anyone have a clue what would cause me to go through 4 M.A.F Sensors in 10,000 miles? changed brands and still keep getting code for mass air flow sensor. could the plug issue i have for the throttle body have anything to do with it?
Old Nov 24, 2013 | 09:13 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Well sounds like u need to do some diagnosing: yes it maybe throwing the code for your maf ... But u really need to look up the proper testing procedure!!! My gess is u have a wire that's shorting out somewhere
Old Nov 24, 2013 | 09:58 PM
richphotos's Avatar
This right here, just because it throws a code for the MAF does not mean the MAF is bad, it could be something else causing it....
For instance, I was getting a code for TPS and MAP sensors, and it was because I had a fuel leak in the Plenum.
Quite throwing MAFs into it and diagnose it.
Which code is the MAF throwing, there should be 2 codes that it can throw.
O_P_PLaya
Headers, Intake, & Exhaust
Sep 2, 2007 01:22 PM
speeddemon560
Mar 14, 2007 09:44 PM
alphagtp
Feb 13, 2007 03:18 PM
chevyrocksu
Nov 15, 2006 10:44 AM
abmoto4
Aug 31, 2006 07:52 PM
