99 ZR2 Suddenly spontaneously switching to 4x4
Old Jul 3, 2015 | 06:54 AM
seriosbrad's Avatar
seriosbrad is on a distinguished road
Default 99 ZR2 Suddenly spontaneously switching to 4x4
This morning my 4x4 has been engaging at will on its own for seemingly no reason. 4hi comes on solid and 4lo will be flashing. I have to keep hitting the 2hi button every 5 minutes to keep it in 2wd.
What are the likely culprits? Since it does switch back to 2wd, I'm assuming the vacuum actuator is fine, but I do have a new spare one just in case.
Old Jul 3, 2015 | 08:26 AM
3-button dash switch or 4-button (auto-4wd)? If 4-button, I would suspect corrosion at the TCCM (passenger side kick panel) since the switch uses resistors to alter voltage returning back to the TCCM. If there is corrosion bridging those two contacts, it can cause what you are experiencing.
abadinalbany
19
Apr 23, 2010 01:39 PM
Baja Blazer 85
Apr 13, 2010 01:15 AM
AdamCrosier
Dec 24, 2009 09:13 AM
Screechny
Apr 23, 2008 03:15 PM
bigbrett
Apr 6, 2006 10:13 PM
