ABS and Brake light come on while driving
Old Jun 4, 2017 | 09:37 AM
Raman04's Avatar
Raman04 is on a distinguished road
Default ABS and Brake light come on while driving
Been happening for a while now, at start up no brake or abs light. After a few miles both lights come on. Following a tip, I pulled the airbox and cleaned a ground cable next to the radiator. Saw a video where you pull the ECM out, cut the seal, open it up and there are 6 points on the circuit board you resolder, then use rtv sealant and reinstall. Does anyone know if that is worth trying? I looked for a sticky, but then again sometimes I can't even find my WITH a bell on it.
Also did recently replace front pass side hub amd no change in Abs light.
Old Jun 4, 2017 | 10:29 AM
Rusty Nuts's Avatar
There is a code that's triggering the abs light. ABS codes are automatically cleared when the truck is shut off. Drive it until the lights come on and have it scanned with a scanner capable of retrieving abs codes.
Old Jun 4, 2017 | 09:27 PM
rxjimmy's Avatar
rxjimmy is on a distinguished road
The easy possibility for both lights "on" might be the master cylinder fluid level is low. IF so, it is about the easiest fix.
Old Jun 4, 2017 | 11:44 PM
newguy's Avatar
you have cracked solders in the abs module. it can be resoldered
Old Jun 5, 2017 | 04:49 PM
Raman04's Avatar
I know the booster diaphragm has a hole in it but I don't think the Blazer has anyway if knowing that.
Old Jun 5, 2017 | 05:59 PM
newguy's Avatar
you need to repair the abs module, just like the video
ussexplorer
May 24, 2017 06:00 AM
run_girl
Nov 7, 2016 02:32 PM
hitmanK47
Dec 3, 2011 04:33 PM
damageinc98
Jul 12, 2010 10:47 PM
Ugly_Monkey
31
Jun 4, 2010 03:06 PM
