Abs Module replacement
I want to replace my Abs Module instead of trying to put a band aid on it.I was told"If I replace Abs Module..I would have to replace the Abs Pump too!"Is this true?"My Abs light is on all the time.I had my mechanic run a scan on it.Come to find out the Abs module is shot.I want to replace it with a new one but don`t wanna to have to replace the pump too.It is what it is if I have to buy both at the same time..I`ll just have to bite the bullet and buy both..
Thanks for your time....
If you replace the brake pressure modulator valve (BPMV) the brakes will need bled using a Tech 2 or otherwise capable scan tool.
Are you certain that the EBCM is bad - or did someone just tell you it was bad, and that you needed to also replace the BPMV? Sounds like someone using the S.W.A.G. system of diagnosis and attempting to include all the things it might be. How about giving us some problem/diagnostic history/ABS codes? Otherwise, I think your specific question is answered.
Good luck and best wishes for a successful repair.
Thanks for the info.
I`m gonna just have my abs module rebuilt at Modulemasters.com for $130.00.Thanks a bunch!
Two year old thread.
Closing it now.
Closing it now.
tshannon76
08-22-2012 02:35 PM
ExplicitYourSelf
04-15-2011 03:10 AM
