AC trouble on a 2001 Blazer xtreme
Old Jun 5, 2011 | 02:51 PM
AraQuest's Avatar
AraQuest is on a distinguished road
Default AC trouble on a 2001 Blazer xtreme
Problem: AC wont blow cold.
Found issues: Upon start up from a long period of down time(4 hours). The clutch will run for awhile cold air will blow then it will stop running and may or may not kick back on intermittently.
I think I have either high pressure or a bad high pressure sensor. I checked the refrigerant and it looked a little high after revving the engine. I released some R-134a. The clutch will engage for a longer period now but it still stops working shortly after taking off down the road.
Questions:
Could this be a high pressure issue?
If it is a high pressure sensor will I have to recover the R-134a, AKA will the R-134a leak out when I remove the sensor?
MeXiCaNcHuLo
Feb 8, 2013 12:37 PM
bluextremeblazer01slammed
Engine & Internal
Aug 26, 2012 02:07 PM
MiStErMaThiSoN
Feb 12, 2012 09:26 AM
matthammill
Dec 20, 2010 04:33 PM
