accelorator pump question
Old Feb 2, 2008 | 06:19 PM
85blazerproject's Avatar
85blazerproject is an unknown quantity at this point
Default accelorator pump question
85 S10 Blazer 4x4 2.8. i bought a new accelorator pump and it looks like to me that you have to remove the whole top of the carbuerator to replace it is this correct? if it is i was thinking i might as well buy a kit and rebuild the whole carb since i will have it apart anyway.
Old Feb 2, 2008 | 06:59 PM
Default RE: accelorator pump question
Would be a worthwhile project. You'll basically already have it apart. Might as well rebuild it.
Old Feb 2, 2008 | 11:33 PM
Chevy Lover's Avatar
If you decide to take it apart, take lots of pictures or you may have a problem re-assembling the linkages properly.
You actually only have to take off the air horn to replace the accellerator pump, but it's a good idea to take the carb off and do the complete cleaning and overhaul.
Old Feb 3, 2008 | 12:10 PM
neo71665's Avatar
Just as well rebuild it if your taking the top off anyways. Most rebuild kits come with a new pump and used to only be $30-$40 and come with all the gaskets you stand a good chance of tearing up replaceing the pump alone.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
junkmonkey
Mar 29, 2007 08:01 PM
mytruck2
Dec 13, 2006 04:50 PM
