annoying knock
Old Apr 15, 2008 | 08:50 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default annoying knock
My engine as long as I can remember hearing it has always made what sounds like an upper engine knock between 1500RPM and 1800RPM. Which leads me to think that it is some balance issue since it only occurs at these rpms. I've driven thousands of miles with this noise and it never gets any worse or any better so I think its fine, but any ideas as to what this is and maybe a solution to remedy it. For further info I use 5W30 Full synthetic usally a better brand not a discount deal.
Old Apr 15, 2008 | 09:06 AM
Default RE: annoying knock
Noise - This is a known problem on some engines for whatever reason. I can post the entire TSB if you'd like.
Old Apr 15, 2008 | 09:36 AM
portcqb's Avatar
Oh thanks, I should have searched knock I expected to get 100s of results. I will look into doing this fix. Ok after doing some searching on this TSB GM says it will not effect durability of the engine and from what I can find its like 250 in parts alone so I think im going to let it knock.
fredguaz
Dec 11, 2017 08:11 AM
ejschultz
May 23, 2009 04:15 PM
Patrick
Jan 22, 2006 12:35 PM
zero psi
Nov 26, 2005 03:37 PM
mkatts
Sep 6, 2004 10:54 PM
