Another Damn Overheating Problem!
Old Sep 8, 2008 | 05:30 PM
SnowRemorse's Avatar
SnowRemorse is an unknown quantity at this point
Default Another Damn Overheating Problem!
alright, so i got a 2002 v6 vortec 4.3. it has been getting unsually hot really fast (hot as in getting up to 210 and alittle above 210degreesquickly). it completlety over heated when i took a trip on the freeway the other day.my heater is blowing cold air. it will blow hot air every once in awhile for about 3 - 5 seconds, then back to cold. when the heat does kick on, the temp will drop to normal.and i just replaced thethermostat. any ideas? water pump maybe? thanks!
Old Sep 8, 2008 | 05:50 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Another Damn Overheating Problem!
almost sounds like a bad heater core..
Old Sep 8, 2008 | 07:23 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
Have you checked your coolant? I assume you've taken this important step one, but if you haven't it would be a cheap fix to your problem.
Old Sep 8, 2008 | 07:31 PM
You must verify that the cooling system is full, there are no leaks, and all of the air is out of the system. Also, if you replaced your t-stat, it is a good time to replace your radiator cap. A weak radiator cap can cause overheating.
Old Sep 8, 2008 | 10:52 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
if you have air in the system it can get trapped in the heater core.. time for a flush...
Blazin_1t_up
Oct 29, 2008 10:52 PM
Thor_449
Jul 24, 2008 08:05 PM
blazin97
Jul 29, 2006 06:36 PM
nslide10
Nov 24, 2005 02:52 PM
nslide10
Nov 1, 2005 06:36 PM
