Antifreeze
Old Aug 8, 2020 | 03:32 PM
Jefflego's Avatar
Jefflego is on a distinguished road
Default Antifreeze
(Haven’t found any related posts)
Should I be running full strength coolant? In a previous post I had an overheating concern and it’s still happening. But I have no leaks at all, no blockages, new pump, new T Stat,.
i currently have full strength Dex in it and wondering if that may be the issue
Old Aug 8, 2020 | 03:57 PM
Billy1820's Avatar
Why are you running full strength antifreeze?
...Are you the guy who said he was using 100% water?
Old Aug 8, 2020 | 04:02 PM
Jefflego's Avatar
no idea who that guy is....I’ve never ran 100% water...
and it’s not that I chose to go full strength, it’s just that I have a never ending supply of full strength so that’s all I’ve been putting in...I’ve never really given it much thought.
“needs coolant top off? Cool there’s a bottle of dex right here so in it goes”
Old Aug 8, 2020 | 04:09 PM
Billy1820's Avatar
good luck
Old Aug 9, 2020 | 12:08 AM
AJBert's Avatar
You need to run 50/50. If that doesn't fix things, look at the simple stuff first. Start with the the thermostat.
Old Aug 9, 2020 | 05:35 AM
Jefflego's Avatar
in my post I actually said that I put a new thermostat in....didn’t change anything....NEW PUMP, NEW T STAT.....oh and I replaced the fan clutch because the old one definitely was bad
Old Aug 9, 2020 | 08:04 AM
rriddle3's Avatar
You need to run 50/50. ..
At the most, 60/40 AF/water.
Pure Anti-freeze Can Wreck Havoc
Old Aug 9, 2020 | 08:08 AM
Jefflego's Avatar
thanks that’s what I needed
Metalslug137
Jan 22, 2016 12:57 PM
mss91z28
Sep 14, 2015 08:13 PM
phxjosh
39
Nov 7, 2013 12:41 PM
jdepew
May 1, 2011 12:21 PM
JediKnight2
Nov 18, 2010 03:02 PM
