antifreeze in the oil
Old Apr 11, 2011 | 04:57 PM
ozziebear's Avatar
ozziebear is on a distinguished road
Default antifreeze in the oil
I found I have coolant in the oil and my machanic told me I need to replace the engine. He refused to check it out to find the cause.
I see in other posts that IF it is an intake gasket oyu can replace the gasket and save the engine.
Any thoughts?
Old Apr 11, 2011 | 05:45 PM
rriddle3's Avatar
First step is to run a pressure test to find the source of the coolant leak and repair it. If the bearings have not been damaged from the water in the oil, you have saved the engine.
mov4x4's Avatar
mov4x4 is on a distinguished road
Yea you can replace them I always thought it was when the head gasket went bad that it caused the oil and coolant to mix.
Travis West
Dec 23, 2014 07:59 AM
95Jimmy
Apr 19, 2011 08:55 AM
sants
Jan 1, 2011 09:48 AM
SWDinehart
Mar 16, 2010 11:31 PM
Spookypaws
Jun 19, 2009 06:34 PM
