Auto 4WD stuck
I've searched for something related to my issue, I believe I'm having a mentally vacuous day because I've not been able to fix the issue. 2001 Blazer with NV236 (4 button) . I can get it to 2wd, not sure what I did, messing with output hose and electrical connector on Vacuum switch on the firewall. From there I can drive in 2wd, stop, restart, still 2wd. I push Auto 4wd button, light flashes as it switches, then solid light, and I seem to be stuck in 4wd, not back and forth, even on clear roads. Will not switch back to 2wd when button is pushed, cant get 4hi or 4 lo buttons to do anything either. Took out battery and tray, cable moves free and easy, does not appear to be stuck, corroded, or broken. When I pull out bottom vacuum hose on Vacuum switch, I can hear the air. Disconnect air line and electrical connector, plug hose back in and then electrical connector, you can hear quiet click or clunk, I think its back in 4wd, even though I'm not moving. Biggest hope is to be able to push "2wd" button on dash and switch back to 2wd. Sorry I went so long, hope I provided eneough detail.
Update, just disconnected both harnesses from TCCM, started, ran forward few feet, reverse few feet, no lights on to indicate 2wd, auto 4wd, etc. Shut off, reconnect all, start up, without me pressing any buttons, starts in 4 HI. Pushed 4 LO, 2wd, got nothing, pushed Auto 4wd, went to Auto 4wd. When I say "nothing", light does not even flash like it is trying to go into 2wd or 4 LO.
Last edited by swartlkk; Sep 10, 2011 at 04:52 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Have you tested the switch resistance? All of the wiring to/from the TCCM/switch/encoder motor? The wiring & other details can be found in the Tech Article (DIY) section; an index of which is linked to in my signature below.
Blazeme
Jan 24, 2015 06:08 PM
blazen_red_4x4
Jun 1, 2014 05:43 PM
Alterac
Aug 25, 2008 08:48 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
