2005 Blazer automatic transmission identification
Old Jul 9, 2009 | 06:59 PM
RA's Avatar
RA
RA is an unknown quantity at this point
Default 2005 Blazer automatic transmission identification
I have a 2005 Blazer with an automatic transmission, Is there a way to run it without the ECM?
I am also looking for information on the tranny I have now... stock 2005 Automatic.
Does anyone have a model number that I can start looking for information on?
I found the for following on a white sticker - 5TAD but can not find anything on that.
I have been looking at doing a swap with a TH350 and an older 350 engine but am wondering if I can get away with using the existing transmission with a few mods or ?
Thanks!
Attached Thumbnails 2005 Blazer automatic transmission identification-truck1.jpg   2005 Blazer automatic transmission identification-truck2.jpg
Old Jul 9, 2009 | 07:29 PM
bandidolenny's Avatar
If you install a manual valve body in the tranny, the computer won't be it's (or your) friend anymore. I suppose you could swap the computer for one that's programmed for a manual transmission... if you could get that to work then you could run any non computer controlled tranny you wanted.
Nice SFA swap by the way.
Old Jul 9, 2009 | 09:18 PM
You have the 4L60E.
Old Jul 10, 2009 | 01:09 AM
RA's Avatar
RA
Do you know how much they are worth without the Transfer case and do you know how much the stock transfer case is worth?
thank you for your help.
Thanks!
luisimartins
19
Jan 14, 2013 04:34 PM
RickBlazer
May 26, 2010 04:33 PM
Supercity
Mar 16, 2010 04:39 AM
ReignVictorious
Jan 7, 2010 11:07 AM
vindy78
Sep 22, 2009 04:17 PM
