Bad catalytic converter and bad bearing hub question!
Old Dec 3, 2007 | 12:04 AM
yazan84's Avatar
yazan84 is an unknown quantity at this point
Default Bad catalytic converter and bad bearing hub question!
I've had a discussion last month about my car slowing down quick. In my last check up the mechanic told me that my catalytic converter needs to be replaced and my right front bearing hub sounds bad. My questions is do they effect on the car speed, and could that be the problem that I'm having with my car slowing down fast?
Old Dec 3, 2007 | 12:57 PM
Default RE: Bad catalytic converter and bad bearing hub question!
A bad front wheel bearing could cause a drag on the drivetrain.
A bad catalytic converter would also limit acceleration so unless you are having problems with upper RPM performance, your cat is probably still OK. The only way to properly diagnose a catalytic converter is with a back pressure test where they would remove an O2 sensor before and after the catalytic converter and read the pressures. They should be pretty close together. If a large discrepancy is found, then the catalytic converter is bad.
Old Dec 4, 2007 | 07:55 PM
Hanr3's Avatar
theres a self help thread on the hub replacement if oyu rinterested.
Old Mar 10, 2008 | 06:53 PM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Hey yazan, had the same problem occuring. When I was at crusing speds on the highway and took my foot off the gas pedal I noticed my truck would really slow down quicker then normal....now I have the constant drumming noise at highway speeds to contend with till I get it fixed
PaulO2288
Aug 6, 2010 12:18 PM
soopahmario
Mar 15, 2010 02:16 PM
matthew.chapman1
Headers, Intake, & Exhaust
Oct 26, 2009 07:58 PM
Blazer4U
Aug 4, 2008 05:12 AM
JEFFO2000
Feb 25, 2008 07:24 AM
