Bad miss and backfire
Old May 20, 2010 | 08:45 PM
TSEJEEPERS's Avatar
TSEJEEPERS is an unknown quantity at this point
Default Bad miss and backfire
2000 S 10 Blazer 4.3 engine.
You guys were so much help to me back in 08 when the inake manifold gasket went out.
Well I am back. Same truck (my son's)
My son was loading his boat up with the engine running and it just quit.
Started it back up and it is missing bad and backfiring.
Throwing codes
PO300 Random/Multiple Cylinder Misfire Detected
PO101 Mass or Volume Air Circuit Range/Performance Problem
PO171 System too Lean (Bank 1)
PO174 System too Lean (Bank 2)
Have no clue where to start.
Suggestions Please!
Old May 22, 2010 | 03:49 PM
TSEJEEPERS's Avatar
Well I replaced the MAF today.
Engine is still backfiring bad.
The only code it is throwing now is PO300. I guess I am getting somewhere???
Really leaning towards the distributer.
Am I on the right track or would this be a waste of time and money?
Old May 22, 2010 | 07:16 PM
rriddle3's Avatar
Having the coil tested might be a good idea.
Old May 22, 2010 | 08:50 PM
TSEJEEPERS's Avatar
Will do! Thanks!
Old May 24, 2010 | 02:58 PM
TSEJEEPERS's Avatar
Got it fixed!
Replaced distributer cap, rotor, wires and plugs. Seems to have taken care of it for now.
Still showing misfire on one of the cylinders but I am pretty sure that is a injector.
Old May 24, 2010 | 10:28 PM
Have you tried running some injector cleaner through it?
iowajoe
Jan 25, 2014 05:27 PM
ussexplorer
Sep 27, 2013 03:38 PM
Gunfighter
Dec 18, 2012 03:14 PM
showteam2008
16
Jan 17, 2012 06:11 PM
pokerface
Oct 20, 2007 01:39 PM
