Bad oil pump?
Old Nov 11, 2012 | 01:15 AM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Bad oil pump?
A few months ago I replaced the head gaskets and since then I have had really low oil pressure and made sure that I have had oil in it. Last night after adding a quart I noticed that it was still knocking and showing low oil pressure on the gauge at idle. When I put everything together on the top end is there something that I could have done incorrectly causing a problem, like not installing the distributor correctly? How would I know for sure if the pump is going bad? Could I have some thing that is clogged?
Any info or help in general would help. Thanks!
BouncingRadical
14
Nov 27, 2015 12:30 AM
Kaser1026
Dec 30, 2012 05:58 PM
Klturi421
21
Nov 14, 2012 04:43 AM
spittybays
Nov 3, 2012 04:12 PM
mtz57
Aug 21, 2010 10:10 PM
