Bad Oxygen Sensor?
Old May 28, 2009 | 07:28 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
Default Bad Oxygen Sensor?
I have been having issues with the check engine light lately and I new it was the EGR valve, when I had it to the shop they hooked it up and got an error code for the EGR and a bad oxygen sensor. I def. trust this guy we have always used him, but im wondering if it idles VERY badly (rough) because of that, he says the oxygen sensor can do that. He wants 40 to replace it and its going it tommorw for that and he is gonna clean the egr valve to.
Old May 28, 2009 | 08:18 PM
blazinloud's Avatar
I belive theres more than 1 O2 sensor.....
Old May 28, 2009 | 08:29 PM
Depending on the ECU/PCM configuration, you could have one or two O2 sensors. Only one of them (the one closest to the engine) is used for fuel management. And yes, a bad O2 sensor could cause idle problems, but typically cause problems more than just at idle.
Old May 28, 2009 | 08:57 PM
The problems im having that I notice, it takes some cranking to start sometimes, other times it fires right up. And every now and then it almost stalls after giving it a little power, can u list the problems and ill see if its anything i notice.
litterbug
13
Feb 1, 2010 10:33 AM
steelcityneal
Jan 10, 2010 09:23 PM
blzR
Nov 2, 2007 10:28 PM
andyjwood
Oct 29, 2006 02:51 PM
jmd57win
Oct 27, 2006 10:24 PM
