bad transmission mount? need suggestions
Old Sep 18, 2011 | 01:33 PM
CNYCountryKidd's Avatar
CNYCountryKidd is on a distinguished road
Default bad transmission mount? need suggestions
So for about... 2 weeks or so not my transmission (i think) shakes quite a bit from 15mph-40mph then settles down, but I can still feel the shake when I'm on the highway. I'm thinking it's a bad transmission mount, i havent gotten under there yet and looked at anything so I don't know for sure. Some days it's worse than others, some days I can hardly notice it. Also, when I go over bumps I can feel something hitting the hump on the floor up front.
Any info/suggestions are welcome, thanks.
Old Sep 18, 2011 | 01:35 PM
chris015's Avatar
Do you have 4x4?
"hump on the floor up front"
Sounds like a bad torsion bar mount.
Old Sep 18, 2011 | 02:21 PM
yea it's 4WD. i dont think its the torsion bar mounts... it's in the middle of the bump where the transmission goes and I can feel it where my foot rests next to the gas pedal
Old Sep 18, 2011 | 03:03 PM
warthogdriver's Avatar
put a jack under the tranny with a board on it and apply a "small" amount of pressure...if mount is shot it will lift up...its easy to fix.
Old Sep 18, 2011 | 07:18 PM
chris015's Avatar
Reason i ask about the torsion bar mounts is when BOTH of mine went bad,i had that same knock under my feet. at the gas pedal. crawl under the truck at the torsion crossmember,and push up on the member where the bars slide into up and down. if they move at all. they are bad.
Old Sep 18, 2011 | 10:00 PM
hmm.. I'll check both of those things probably Tuesday when I'm out of class
Rottidog
May 17, 2012 12:32 AM
mtz57
Aug 21, 2010 10:10 PM
Drifter666
Sep 15, 2008 02:35 PM
95Blazer4x4
Feb 1, 2008 08:19 PM
6wraith
May 9, 2007 06:56 AM
