badddddd problem..need yoru help/advice
Old Mar 3, 2007 | 04:13 AM
nine5blazer's Avatar
nine5blazer is an unknown quantity at this point
Default badddddd problem..need yoru help/advice
i have a 95 2wd 4 door blazer
problem is my tranny..or a connection on the tranny..or somethign else that i have no idea..but my buddy has a GM Tech2 diagnostic tool and when we hooked it up..the only codes it threw were VSS circuit loss and EGR valve..now my question is
will a bad EGR tell my computer to shift funny?? when we hooked up the tech2..we coudl drive perfect if he manually shifted it with the tech2..but when he turned off the manual shifting..it would shift 1-2-3 1-2-3 1-2-3 over n over real fast and it would jerk and downshift and upshift real fast...sometimes it locks into 2nd gear..then other times it locks into 3rd gear..now i kno it cant be the tranny(maybe) because when it runs fine..it doesnt slip or hesitate..it has its times where it runs perfect..then the next day i can barely make it to work..and when it does act good..it usually is ended by a nice bump in the road, which leads me to believe its a bad connection on some wire going to the tranny
but can the bad EGR tell my computer when to shift?
i put a new speed sensor on it already(was told that was the cause) but that didnt help
anyone else have any problems like this?? any help would be great
thanks
Philip W
Old Mar 3, 2007 | 12:51 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: badddddd problem..need yoru help/advice
No the EGR valve will not cause that problem. The VSS circuit will cause the problem. Just because you have that code does not mean that the sensor is bad. If your buddy has access to a Tech2, then he should be able to know how to check the wiring in that system to see if it is a wiring issue or a bad ECM. Post the actual code numbers, and I will post a trouble tree for diagnosing that problem. Korey
cdw78
22
Jul 23, 2011 07:56 AM
smg614
Jun 21, 2011 12:13 PM
spaceapex
May 20, 2010 07:34 PM
TerribleOne
Suspension Tech
Apr 27, 2005 03:50 PM
