Guys I need advice on a transfer case problem
Old May 19, 2010 | 02:15 PM
spaceapex's Avatar
spaceapex is on a distinguished road
Default Guys I need advice on a transfer case problem
I have a claning noise coming from the transfer case most notable at around 25mph. I have searched the forums and net for info and sounds like the chain. What I can't find is how to repair it myself. Any one have a lead on a good tech article? The shops want 1grand to rebuild. I wonder if i pull the front of it apart if there is any adjustment to make to the chain?
Old May 19, 2010 | 07:25 PM
What transfer case do you have? If you have the push button system, it likely is the NP233. Have a look at RSGear.com as well as Drivetrain.com.
Old May 19, 2010 | 08:12 PM
spaceapex's Avatar
it is the 233... are they all interchangable from 95 up? found one on ebay from a 99 but he said the model tag is gone.
Old May 19, 2010 | 08:17 PM
Should be. You have to make sure that it is an NP233 though. The NP236 isn't compatible with the electronics in your truck..
Old May 20, 2010 | 07:31 PM
spaceapex's Avatar
IF it is just the chain can i get to it and repair it somehow without removing the entire case? Just trying to avoid the 1200 bucks I was quoted on to rebuild the tcase. Couldnt believe how much they want. checked 3 places by me. I was hoping I could just remove part of the case and adjust the chain if possible. Would tcase issues also throw trans slipping codes?? started getting them recently also. THANKS FOR REPLYING!!! I need to say I am a hot blond or something to get more replys.
Old May 20, 2010 | 07:34 PM
$1200... LOL Wow... That's rich.
If you are sure the problem is inside the t-case, why not try to find a good used t-case to swap.
And no, you cannot pull it apart while leaving it up on the transmission. That wouldn't be good.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
smg614
Jun 21, 2011 12:13 PM
blazergeek1775
Jan 31, 2011 11:22 PM
