Beef up the v6 or convert to a v8?
Old Nov 17, 2013 | 08:29 PM
Bobcat13's Avatar
Bobcat13 is on a distinguished road
Default Beef up the v6 or convert to a v8?
I have a '97 Blazer 4x4 LT and I am torn between replacing the 242K mile-ridden 4.3 with a new one and just beefing it up a bit or with a v8. What are the pros and cons of both?
Old Nov 20, 2013 | 07:33 AM
jimspahr@msn.com's Avatar
How are you going to use the Blazer? Heavy towing, drag racing, extreme off roading? If none of these, I suggest replacing the 4.3 with a GM reman. 4.3L. I think some research into the amount of work to put a V8 into a 4WD Blazer with help you decide against that project.
Old Nov 20, 2013 | 11:14 AM
Diaita's Avatar
Pros: Power. Cons: More work. Fuel economy suffers a bit, but not bad. Putting the engine in is only part of it. The differentials aren't up to the torque of a V8.
Old Nov 21, 2013 | 08:38 AM
Isn't installing a V8 in the 4WD harder to do than the 2WD version? I have read that it is. I want to admit when I first got interested in buying a Blazer with the 4.3L V6, I daydreamed about a V8 swap. But when I got it and drove it, the power was surprising. I am now happy with the stock V6, since I only tow (occasionally) a light one axle trailer. RE: the fuel mileage. I am not sure you would lose much MPG with the Chevy V8. I have a friend with a 1996 GMC Yukon(stock) and he gets 19 mpg hwy, where my 2003 4.3L is only getting about 17 mpg combination hwy/city. That, of course, depends on keeping your right foot off the loud pedal.
Old Nov 21, 2013 | 12:58 PM
Diaita's Avatar
A 4wd V8 conversion uses a few different parts than the 2wd, but I wouldn't say it's harder.
In some conditions, I'm sure the V8 would get better mileage than the V6, but we all love the skinny pedal.
A 50 hp nitrous kit would bring you up to the same power as the V8. Just sayin...
01-4.3l-5spd
Performance & Brainstorming
20
May 22, 2015 09:28 AM
GetNice24
Tires and Wheels
Dec 29, 2009 08:51 PM
davidstl25
Engine & Internal
Dec 18, 2008 08:26 PM
Aquahallic
Jul 30, 2006 05:51 PM
c4gibson
Jun 6, 2006 02:11 AM
