Belt pops off when ac or defroster is on. PLEASE HELP!!!
Old Aug 23, 2009 | 03:53 PM
92K5BLAZER's Avatar
92K5BLAZER is on a distinguished road
Exclamation Belt pops off when ac or defroster is on. PLEASE HELP!!!
I have a 1992 full size blazer. It has a 5.7 liter fuel injection engine in it (stock). It runs good but whenever i have the ac or the defoster on the belt pops off. Without the engine running, i turn the ac on and it blows cold air. Also while the engine is running, thier is hardly no movement on the belt, when the ac is on it starts moving tons only on the ideler pulley untill it falls off. As you can see in the picture it pops off number 22. What is causeing this and how can i fix it? Please help it is now summer getting up to 95 degrees here and its killer. please help and fast.
Old Aug 23, 2009 | 04:05 PM
Since the common thread here is that the A/C compressor clutch is getting engaged... It could be a combination of problems. If the A/C works ok before the belt gets tossed, I would think that it is a problem with the belt and/or idler pulley.
Old Aug 23, 2009 | 04:09 PM
92K5BLAZER's Avatar
is it easy to install a new pulley?
Old Aug 23, 2009 | 07:01 PM
I meant to say tensioner. If the tensioner is not holding enough tension on the belt, it can cause it to jump off. Check all of your pulleys for wobble or gritty turning to see if there may be a problem there, but I would bet that it is a weak tensioner.
lionel2
Sep 7, 2012 02:45 PM
BlazerWare94
Nov 30, 2010 12:32 PM
92K5BLAZER
Jun 27, 2009 11:59 PM
bigbrett
Apr 6, 2006 10:13 PM
