4x4 help engages then pops fuse..
Old Nov 30, 2010 | 11:05 AM
BlazerWare94's Avatar
BlazerWare94 is on a distinguished road
Default 4x4 help engages then pops fuse..
lately ive noticed that mud or sand, i engage 4hi and it works for about 8 secs then puff the fuse pops. so i disengage 4x4 put another one and puff again it pops it. sometimes i get lucky and it stays on for about 1 min or so but other than that its quick to pop.. anyone out there have any tips on how to find the problem and solve it?>
btw its a 94 Chevy Blazer Z71 and before this started to happen the 4x4 would work like a beauty. so yall plz share anything that could help me out PLZ!!
Old Nov 30, 2010 | 11:15 AM
It is very likely that it is the actuator for the front axle. They are kind of in a vunerable spot and can get cracked allowing water in, shorting out the electronics.
Old Nov 30, 2010 | 11:18 AM
is that the plug that is ( i think) on top of the t-case? because i know a while back i just wrapped it around in black tape....
Old Nov 30, 2010 | 11:32 AM
The front axle actuator is on the front axle itself. It is located to the passenger side of the differential 'pumpkin'. The original actuator in your truck is an electro-magnet. GM has since revised the design and has a kit that will upgrade it to the stepper motor version which doesn't draw anywhere near the current.
Here's a quote found using "magnet+stepper+motor+actuator" as a search query:
Originally Posted by swartlkk
THIS POST covers the stepper motor actuator and the harness which may be required.
And the link below will walk you through the install:
GM Fullsize Truck 4x4 Actuator Upgrade - GetDieselPower.com
Old Nov 30, 2010 | 12:32 PM
wow u know wat ur talking about! lol thanks for the info ima end up doing the upgrade soon it should work and i read through it and it answered all my Q's thanks !!
Xavier
Jan 31, 2012 06:22 PM
hawk45
Dec 18, 2010 10:08 PM
blazer4life
Nov 22, 2010 09:09 AM
leatherneck3112
Oct 4, 2009 10:28 AM
redblzr4x4
Jul 14, 2009 02:10 PM
