Belt Routing Problem
Old Jun 19, 2009 | 06:45 AM
BlazinInDaBlazer's Avatar
BlazinInDaBlazer is on a distinguished road
Default Belt Routing Problem
Hey guys, my first time here, and my first post. I have a 2001 LS blazer, and (please bear with my mechanical ignorance) the belt that runs around the pullies is fine. however there is a pulley that turns, then stops, then starts turning again. it is the top right pulley. I have no idea what it is called, nor what is causing this? if anyone can help it would be much appreciated! thanks a lot
Old Jun 19, 2009 | 07:11 AM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
if i am correct its is the a/c compressor.
NVANZEE's Avatar
that is normal. That is the AC clutch
TripleBlackBlazer's Avatar
If you have air conditioning that's your AC compressor and it's not supposed to run 100% of the time.
If you don't have air conditioning we can go from there.
Old Jun 20, 2009 | 12:41 PM
damn. AWESOME guys thats such a relief...however lol, the drive belt tensioner (according to the diagram above) kinda has some free play and shakes a little..is this normal as well?
TripleBlack, Nvan, 86Blazer...thanks for your answers, i appreciate the feedback
Old Jun 20, 2009 | 01:36 PM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Define "freeplay"? If while the engine is running and you notice the tensioner going back and forth about 1/2", that would be normal. Anything more and you may need to replace the belt due to stretching. Someone may come in and verify from the book how much freeplay is allowed.
Old Jun 23, 2009 | 10:41 AM
i see..I do "notice the tensioner going back and forth about 1/2"", so that is normal. that was the freeplay i was referring to. thank you guys again. this is a kick @$$ forum! fast and good advice!!
lionel2
Sep 7, 2012 02:45 PM
gmcjimmy_94
Jan 16, 2012 11:20 PM
RWCastor
Jun 1, 2011 08:14 AM
Xtreme187
Aug 13, 2010 10:27 AM
