Belt tensioner pulley removal question
Old Oct 29, 2013 | 06:59 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Default Belt tensioner pulley removal question
on the actaul black pulley that has the bearing in it, there is a bolt through the center that holds it on, which way do you turn the bolt to remove it? is it reverse tread or standard tread?
Old Oct 29, 2013 | 07:09 PM
Blazer 98's Avatar
Blazer 98 is on a distinguished road
I believe it is standard, so lefty loosely.
Old Oct 29, 2013 | 08:35 PM
richphotos's Avatar
I am not sure on this, good question, as I know on the first gen you go to the left to take tension off the belt to remove it, and i was putting quite a bit of pressure on that bolt to keep tension off the belt and it did not break free,
Old Oct 29, 2013 | 09:01 PM
Hollywood411's Avatar
Hollywood411 is on a distinguished road
Your refering to the solid black pulley on the right of the alternator right? Or the tension relief pulley?
Old Oct 30, 2013 | 12:57 AM
chris015's Avatar
its reverse threaded. right to loosen,left to tighten.
Old Oct 30, 2013 | 07:04 PM
are you 100 percent sure? i can't afford to damage anything so thats why i want to be sure. 3 guys on the other s10 forum said its standard tread but it can't be. just like the guy wrote above , i was putting quite a bit of pressure on that bolt to keep tension off the belt and it did not break free... Chris, if you have done this before, please let me know?
Old Oct 30, 2013 | 08:39 PM
chris015's Avatar
both tensioner pulleys ive pulled of cpi was reverse threaded. 100% sure on the 2 i did. could the one you have be normal? maybe...but probably not. just speaking from what ive done.
Old Oct 30, 2013 | 09:24 PM
Blazer 98's Avatar
I did my belt tensioner pulley a week ago or so, but I have a 98 blazer, it was lefty loosey, I'm not sure if that is what you are talking about.
Old Nov 6, 2013 | 05:10 PM
so far i agree with you. will have to try it to confirm though....
Old Jan 11, 2014 | 03:38 PM
ShadowHawke's Avatar
ShadowHawke is on a distinguished road
The bolt is reverse threaded. I just removed the black pulley (the one with the bearing) on my 1995 S10. Turn the bolt clockwise to remove, counter clockwise to tighten.
