Blazer 4.3- manufacturer date 12/94(transitional year) Help!!
Old May 1, 2021 | 09:16 PM
Melyssa-Remedy Love's Avatar
Melyssa-Remedy Love is on a distinguished road
Default Blazer 4.3- manufacturer date 12/94(transitional year) Help!!
I have a 95 blazer (manufactured 12/94) that won’t start. It ran but after replacing fuel pump, I drove it and it overheated in less than a mile. It hasn’t started up since. With starter fluid I could get it to turn over but soon as starter fluid would burn up, it would shut off. Basically it wouldn’t start up without it. So far the parts that I have replaced are Starter, coolant temperature sensor, cap and rotors, fuel pump, ignition coil, spark plugs, spark plug wires and all relays. I have checked all fuses, made sure there is gas, and it won’t turn over. I noticed a crank position sensor has no wires to plug into. One more thing I found 3 black wires connected to each other but just hanging near firewall. I mounted it to the frame. Anyone have suggestions? Please help, so frustrated with this!!
Old May 2, 2021 | 04:59 AM
First question, does it turn over with the starter or is it locked solid?
At best we would get a picture of the crank position sensor and the three wires you assumed were ground wires.
Old May 23, 2021 | 03:25 AM
Mods's Avatar
Crank sensor harness should come down off the main engine harness on the passenger-front side of the engine bay, to the left of the alternator/idler assembly bracket.
acerocks666
Feb 16, 2020 06:24 PM
er0ck273
Jul 29, 2014 07:20 AM
sutterdan
Mar 1, 2011 01:00 PM
Bootyjones
Feb 9, 2010 06:09 PM
baldmikey96
Jan 2, 2008 09:10 PM
