Blazer engine miss
Old Apr 12, 2017 | 02:39 PM
dardamar's Avatar
dardamar is an unknown quantity at this point
Default Blazer engine miss
1996 Blazer has had an engine miss lately while going down the road. The miss starts at about 2000 rpm and goes away when I accelerate but as soon as I go to cruising speed it starts missing again.
I replaced plugs and wires, cap and rotor and it still misfired. Next thing I tried is unplugging the mass air flow sensor and the misfire went away! So I bought a new MAF sensor and installed it and the engine miss is back.
Only code I've received is P0300 one time. Anyone have any thoughts?
Old Apr 12, 2017 | 07:13 PM
newguy's Avatar
One of the plugs is misfiring, could be a loose plug(happened to me) arcing wire, cheap cap. Check under hood at night in the dark, (unhook underhood light) look for arc sparks on 1 of the wires or around plug. Look hard can be tough to spot sometimes
Old Apr 13, 2017 | 10:02 AM
dardamar's Avatar
If one of the plugs are misfiring why does it run fine with the mass air flow sensor disconnected?
Old Apr 13, 2017 | 10:22 AM
newguy's Avatar
Dont know, but an 0300 is a misfire. And checking is free
Old Apr 29, 2017 | 04:51 PM
dardamar's Avatar
Just a follow up but I ended up replacing the computer as the miss is gone!
ussexplorer
Sep 27, 2013 03:38 PM
Hurm2006
Feb 16, 2013 10:57 AM
scott_wheels
Jan 26, 2010 05:49 PM
harpomania
Dec 27, 2009 04:42 PM
amxal
Mar 2, 2008 05:25 PM
